2007 Honda BF90D HP
Found leaking water from corroded thermostat housing area. It looks like aluminum corrosion is where O-ring sits. The one from the main Cylinder block behind the Electronic Parts Case.. I'm Looking for best practices to fix this.
I'm thinking clean with scotch pad first, aluminum acid wash then use marine slow cure JB weld. I'm not sure of best acid wash?
From The Cylinder Block, It's the Thermostat area Item #9,
http://www.boats.net/parts/search/Honda/Outboard%20Engine/2007%20and%20Later/BF90DK0%20LRTA/CYLINDER%20BLOCK/parts.html
Please note i have not yet cleaned the housing area:
