"I was out yesterday and I had
"I was out yesterday and I had to use reverse , when i went to go back into drive, the engine was still engauged in reverse. When i started checking it out, it turned out that the black plastic piece that goes up by the ESA switch that holds the end of the cable had the 2 little retaining bolts loose. I slipped the cable back in the plastic end and i tightened the bolt up a little too tight and stripped the one side out. what the heck is the name of this thing and where can i go to get it? I stole someone elses picture to show this but its the same thing. Its that black piece at the very bottom with the square bolt heads comming out of it.
