The latest news need new idea
txny13
as in other post i have oil an
as in other post i have oil and whithe smoke coming out my exhust port took raw water pump out and there was black oil in there and the oil cooler is full with the same no water in site. any one with a idea
"White smoke is normally water
"White smoke is normally water converted into steam, although sometimes it could be oil.
For starters, you should find how good or bad is the engine compression. If low or questionable, do a leakdown test and try to find out where the compression is being lost.
I don't see many ways of oil reaching the raw water pump, unless it finds its way from the crankcase, in which case seals 9 and bearings 14 are probably toasted."
