sandkicker
Outstanding Contributor
Background...
Factory new (mid summer 05) FWC 260 HP Merc 5.7 MIE (TKS carb) ran fine mid summer last year and then one day last September, it suddenly started to stumble at very low throttle openings. What I've done since then ( this has been posted here before)
Last year...
1) removed fuel filter ( Merc w/water separator)... drained it ( no water) refilled it with seafoam and ran the engine.
2) New plugs, cap, rotor (from the auto store)
3) cleaned carb
4) Found a metal shaving that drifts in and out of the gap between the idle mixture screw and the body of the carb. Removed it.
5) Triple checked firing order
6) retimed engine in base mode, reset idle.
Still no joy... pulled boat out for the season
This year
1) New cap, rotor (Mercruiser)
2) retimed in base mode.
3) reset float level to numbers in the book (never been changed before)... it was almost 3/16 of an inch off (high as I recall) on both numbers!
4) bought mixture adj tool and put engine in base mode at 650. Screwing the adjustment in does seem at one point to make the engine run rougher, however, backing it out past the point where is stops misbehaving (about 1/4 turn) has no apparent further result.
Further refined troubleshooting reveled that with the engine running at 650 rpm in normal mode, opening the throttle (at the carb with the cable disconnected) ANY amount causes the engine to stumble and stall dead.
If I reconnect the throttle cable and shift it into gear, it goes into gear and will idle, in gear, however...any small throttle increase in gear (or out for that matter) and it stalls.
If I "goose" it, everything's fine ( in or out of gear)... it revs up OK. HOWEVER... with a 2 ton boat and a 15x21 prop..."goosing it" when you first get into gear to keep it from stalling has potentially "amusing" results, especially when docking ( stern in to a bulkhead).
5) replaced the accelerator pump ( I called my brother in law who has a carry permit to accompany me to the dealer to pick up this part that apparently is worth half its weight in gold at $60+)... just kidding but for crying out loud $60!!!!... same result
6) Tried all three settings on the accelerator pump arm.
7) Shut fuel valve off, restarted engine and opened the throttle several times...engine stalled every time regardless of fuel level in the bowl, so its not likely a float level problem.
No joy... It got dark and I called it quits.
Boat has been in the water since early June and not out of it's slip. Per the title of the post... The "Admiral" getting unhappy.
Other observations...
When in base timing mode, idle RPM tends to "hunt" .... but not like the "normal" hunt from a hot cam, i.e., fast pickup, fast slow... it seems to be more of a wander.
Oh yeah.... fresh gas... tank pumped dry in spring and refilled with mid range gas (engine uses regular gas)
Idle RPM is also not stable ( as in its not always the same rpms) and as far as I can see would be more stable if the throttle arm had a return spring (if I push on the arm at the carb, it behaves). But this really has no bearing on the problem that I can see.
I'm starting to run out of ideas and tomorrow I'm planning to give the engine another shot of seafoam , for no good reason, since I started with that last season when the problem first cropped up and had the carb 99% apart and cleaned this spring. I have another set of plugs (platinum), but this problem started with the factory original platinum ( with less than 50 hours on them) and there is a non platinum set in there now with about 2 hours total ( less than 1 hour with the boat moving) on them.
As it is now, the boat is almost impossible to dock in the marine that its in. Unless you put it in neutral, coast up and hope you get close enough to snag a line with a boat hook. (boat does about 4 knots at idle). Docking it under power is a "tap...tap" in/out of gear kind of thing when the engine behaves... now... it's "dummy docking" only.
Any suggestions? I'm not a fan of the shotgun troubleshooting method... but I've run out of ideas except another set of plugs and a compression test... and I don't see that being other than a waste of time, however...!
Sorry for the long post...
Last year...
3) cleaned carb
This year
