J
Jim Roberts
Guest
" Dear Joe Reeves,
Thanks for
" Dear Joe Reeves,
Thanks for the great advice on the waterpump impellor and how to check my warning Buzzer. Job went smoothly and appears to be pumping fine and the alarm buzzer is functional.
Can I pester you for more tips? The patient is a 71 3cyl 60 HP E-rude electric shift. After the maiden voyage the other day (Pushing a 16 foot tri-toon) had some issues with stalling and fouling I'd like to discuss. I can get it running ok, and it will idle up and down fine. But when I put it into gear it would bog and quit. eventually i got it to chug up and got it to a throttle setting that wouldn't stall. Then up to full it ran smoothly and quietly with no probs. Then shut it off, and it would start very hard, and I had trouble getting it to engage and push as it would stall under load almost every time. got it back to dock and noticed some things that I would love your comments on.
1. Found a pinhole leak in the fuel line "bulb" so I probably had some air intrusion to the fuel.
2.I notice that to get the solenoid shift to function I had to turn the ignition off completely and then put into nuetral. If I stalled and didn't de-energize the ign/shift system completely it would stay in forward adn still try to start.jsut pushing the Nuetral button did nothing. Normal op?
3. I eventually fouled one of the plugs. # 1 (top) cylinder looked like the plug was gooked up pretty good. #2 looked like it was ok but headed towards fouling and #3 looked clean. It also used a lot of fuel for a short ride. I know a fuel line leak doesn't help..but anything else.
Compression is 110 to 120 psi on all cylinders.
4.These are the gapless center fire plugs. NOTE!
The top cylinder appears to have been heli-coiled with some kind of insert that has the plug approx 1/8" further out than the lower two plugs.
5. Exhaust through the prop is clean and no oil residue. Of course the gravel I dragged it through could have polished that off (kidding) but it sure does a number on the prop edges...guess that's why it's Named "The Rock River"
Anyway, any helpful tips on setting carbs or idle so I don't stall out and start a little easier would be appreciated. Thanks again.
Also to everybody else who has helped.
JBR "
Thanks for
" Dear Joe Reeves,
JBR "
