ssherbundy
The idle on my 95 Johnson 50hp is just terrible. The engine runs terrific at full throttle and accelerates without hesitation. I suspect that the fuel enrichment solenoid (cold start solenoid) may be leaking and flooding the engine when in the normal or run position (valve turned toward the solenoid body). I want to test it on the engine. The solenoid does work and fuel enters the hoses to the carb(s).
If I understand correctly, when the the valve is turned to the "run" position it should not pass fuel to the carb(s) without the solenoid being energized by the start/ignition key being depressed. And when the control valve is in the opposite or fully or partially open to the manual position (pointing toward the toward the hose fittings opposite the solenoid body) it should pass fuel through the hoses to the top of the carb(s).
Will it be a valid test to remove the hoses that enter the top of the carb(s) while cranking the engine with the kill switch in the "kill" position to note if any fuel flows past the valve and its diaphragm and to the hoses with the solenoid not energized by the key position?
