I have a 1973 65 HP Evinrude that is giving me issues with starting and have drilled it down to being the starter solenoid. When I try to start it the solenoid just makes a loud clicking noise. It has not been replaced in a long time and might be original. I know it is not the safety neutral switch as I am running the ground to the motor (controls have a safety neutral switch in it). I drilled out the rivets to inspect the inside and noticed a small amount of corrosion so I cleaned it up and it works most the time now. I decided to replace this as I knew it would be a temporary fix and the new one installed doesn't work or make a sound. When I bench tested the old one I ran a positive directly off the battery and a negative to battery to the small posts and it works. The new one does nothing with the same test. I know I got the right replacement as it looks identical. Do I have a bad new solenoid?
Thanks for the help.
