Test Tank
lucky_d
"I need to do final adjustment
"I need to do final adjustments to my 40 hp Merc. Is there a way I can make a test tank to do these adjustments, the book says I need to open the throttle wide open while running. Can I do this in my driveway?"
"Do the adjustments in the wat
"Do the adjustments in the water with the boat on the trailer tied down and conected to the car
I disconnect the linkage that
I disconnect the linkage that opens the carb(s). You can safely do the timing that way at full throttle in a barrel.
Jeff
