get the proper lights to come on have the correct batt, power while out today, A 12 volt system no
remote auto on this unit but when I press the continuous button on the pedal no prop turning nor power head will respond. When trying the foot pedal manually same results nothing,
i do have green light to comes on when continuous is pressed.
Power head light shows system activated.
strong Batt not an issue has worked fine for months this morning while out using the system it operated perfectly. then nothing, tried raising an lowering unit, disconnected the quick disconnect for the pedal....
unit has a kill type switch feature when the unit is placed in the cradle up right, is there fused issue at the lake an no manual.
all worked perfect b4 need help thanks
