Twin 1984 Crusader 454’s. Both engines idle and run below 1800 RPMS at 160F rock solid. However at a 3500 rpm cruise the port motor goes to 180F; starboard increases to about 170F. Throttle back down to 1000 RPM’s and the starboard temp drops back to 160F within 30 seconds; the port motor takes several minutes to return to 160F.
Other observations. There is a suggestion of rusting at the elbows/risers of the port motor, and I noticed some significant flakes of corroded cast iron when I replaced all the coolant hoses on the port motor last year.
The heat exchanger on the port side was removed and cleaned and the impellor on the port side is new. The starboard impellor is older and the heat exchanger has never been cleaned, yet this motor only has about ½ the temp. rise and returns to baseline quickly.
Both gauges and senders are the same and new last year.
I think the exhaust system may be partially restricted by rusting elbows and risers and foresee a new set of elbows and risers on the starboard side. I have a infrared temp gun and want to shoot some riser and exhaust temps on both sides at cruise but its tough to get the wife to turn up the engine beyond about 1200 rpms.
What do the experts think?
What is an acceptable temperature rise?
What is the “Do Not Exceed” engine operating temperature?
I'm aware 180F is now the recommended operating temperature but I don’t like the 20 degree rise and I am worried I have lost some cooling capacity and some day soon it might go right past 190F.
