sandkicker
Outstanding Contributor
The trouble apparently started two years ago with a slip and fall that ended up with my foot neatly breaking off the end of the much hyped Blue Plastic drain valves on my circa 2006 MERC factory (5.7MIE) FWC engine. Anti freeze started running out! Fortunately no one had a camera or it would have been on You Tube. Finger over end to stop the leak, stretch to reach cell phone call to wife with other hand to get a suitable can, scramble with a large coffee can to catch the antifreeze and transfer it to another larger container until the level dropped to almost nothing. I replaced the blue valves with brass plugs and refilled the system with antifreeze.
It took me awhile to notice it but yesterday I paid attention to when the engine went from enrichment 1200 RPM idle to 650 RPM. I had checked the manual and this transition point should be in the 130 to 140 degree range. Now it does not change (the "hiss" starts to moderate and engine RPMs drop) until Temp rises to just over 160 degrees and then drops slightly, i.e., when the T'stat opens. IF you watch closely, you can see the temp gauge go up and down a few degrees as the T'stat opens and closes at idle. (Was recharging a bilge pump depleted house battery)
It seems to me as if I might have a air pocket in the engine. Some other marine engines I've owned had a air bleed valve near the T'stat housing. So far as I can see, this one does not have one. The heat exhanger is full of antifreeze on the engine side. I don't think that the sensor is funky as it would too much of a coincidence for it to fail by changing from 130 to 165 degrees.
I first noticed problems last year with a wandering idle when traveling at idle for long distances , i.e., idle would go from 650 in gear to 1100 and then shift back after 30 secs to a min. I'd posted this last year on this forum and never found the problem. It had been a ratty boating season due to personal/family schedule so the boats not been used much at all ( 3 times all summer! July to Nov!)
