dock_holiday
"Hi all. The temp gauge on my
"Hi all. The temp gauge on my 1972 AQ 170 is the VP one with a green arc with a red wedge at the "hot" end of the arc on the face of the gauge. If you have seen one you will know what I mean. If not I am sorry for the poor descrition!. There are no numbers to on the face at all. Anyway, when I run the boat with no thermostat the needle on the gauge never gets higher than about 1/4 up the green section of the arc. With the thermostat in it will run up into the start of the red real quickly if I am running it at high revs or working it hard. This is the area on the arc where the needle covers some green and some red. If I don't take action to lower the temp the needle will climb right on up into the middle of the red section (very scary!) I can get it to go back down into the green if I hold it at a high idle like 2000 RPM for a minute or so. I know the impeller and the circulating pump are good. I just looked at both of them, and the fact that w/o the thermostat the gauge shows nice and cool tells me the pumps are working. There seems to be a delay in the cooling effect... the needle goes to the hot end of the arc faster than it goes back down. I suspect at I have either a bad gauge or a bad sender, or a bad thermostat. I know the thermostat opens and closes because I put it in hot water and watched it do so before putting it back in the motor. Maybe i have the thermostat in upside down? I installed it the way it was when i took it all apart. what would be the symptoms of a thermostat installed upside down? Anybody have any thoughts on where to start with this? --- or should I just pull the thermostat and run without it? (I am guessing El P. says no to that idea) LOL.
Thanks in advance, and sorry for the long post--trying to be thorough.
Matt"
Matt"
