Blackfin29combi
Having an issue with my port engine when bringing boat up on plane it gets to around 1800rpm and then falls off to idle. Bring the throttle down and back up and it runs back up to 1800 then back to idle again. It has been going on for a couple of months and every now and then when it gets up on plane she will run fine for miles. Fuel is clean as is all filters. Pressure checked fuel while problem occurs and pressure stays at #19lbs and doesn’t flinch. All gauges are reading good temps as they should. Replaced oil pressure sensor, coolant temp sensor, trans temp sensor, ignition module, rotor and cap. Also swapped ecm and tps with starboard engine and still the same. Engine runs fine at any rpm in neutral. Not sure where to go next and any help would be appreciated. Maybe knock sensor,map sensor???
Mike
Mike
