stringer_bell
"Cleaned heat exchanger with l
"Cleaned heat exchanger with long wire, about 20 percent of tubes were clogged. Removed one thermostat temporarily. Ran motor at idle with HE front cover off, and there was good water flow...this tells me oil cooler and HE are relatively clean and are flowing raw water. With HE front cover off I pulled hose on exit side of exhaust elbow, and did not see water coming out of there...and when I put HE back together it still didn't seem like exhaust elbow was flowing...and it kinda makes sense, it seems like my raw water is stuck in the motor. Should I try to clear/clean the exhaust elbow? Just run wire thru stainless sleeve and clear blockage, or just buy new and replace? I hope I am narrowing this down....ran boat today and its 175f at anything below 2000rpm....over that it shoots to 210-220f and is very very slow to cool off once I get back down to idle."
