I acquired a boat and it has one of the two TAMD41 B engines smoking badly. The previous owner had the injection pump off. I find in Timing this engine I can't adjust the pump to the spec because the pump is against the mounting bolts and it needs to move slightly further. I have come to the conclusion that the timing gear is one tooth off. I have tried to reposition it but there doesn't seem to be enough space. Can somebody tell me if it is possible to move the gear one tooth back without disassembling the front housing and crankshaft Harmonic Balancer
