Crawford Alexander
Hi All
I have one engine registering a lower than operating temperature than the other.
Is this more than likely to be due to a coolant sender issue ( rather than the coolant switch?)
Last year i had issues with a presure sender which had to be replaced on same engine.
On a side note i also have slightly persistant white smoke/vapour emitting from the exhausts and the turbo can be a little sticky from time to time when the boat has been sitting for periods.
Is their any remedy for this?
I'm not too concerned about the smoke issue , but if it is inter-related with a performance issue then i would be keen to address the problem.
The engine is 305hp engine with a max speed of about 17.5 -20 knotts on a good day-was advertised as 25 knots
I feel that it could do better , but its also an old fairline circa 20yrs old.
I could get an engineer friend to do compression tests and look at injectors but would be keen to exclude more simpler/obvious issues first.
And advice greatly appreciated
crawford alexander
crawford alexander
