My tachometer wasn't working at all on my 1972 Evinrude v4 100hp (100293R) so I installed a new the tacho gauge setting it to 6 (from everything I've read what it's meant to be set at for this motor) but without success.
So then after doing some reading I tested the rectifier and replaced that after finding it faulty.
Now the Tacho started to work (kinda) but it won't read at low rpms eg. anything under about 1300 rpm the needle goes straight up to the max rpm of the gauge around 8k and then as you increase the revs the needle drops down to 1400 and then the gauge starts working as normal.
I thought there could have been some problem with the wiring (having some sort of resistance somewhere along the line) so a ran a new wire directly from the rectifier/stator connector to the back of the gauge but had the same result.
Just wondering what could be causing this problem and what I can do to fix it?
Just to note the charging system of the outboard seems to work eg I can see the volts slowly rise with the rpm eg. around 13V or so at 2k rpm
Cliff
Cliff
