Hi, added a tach recently while prepping a new hull. While engine was on the ground, hooked up tach and engine, cranked and got a tach signal. Finished rigging the boat and now have no tach. Verified power and ground to tach, Have proper pole selected and tach was tested when purchased. Disconnected tach wire from engine and put dvom to yellow wire at rectifier, should be 2.0v or greater getting just a few tenths. Also noticed on maiden voyage that the battery did not seem to be getting charged, though it is tough to say as we ran a baitwell pump all day. Can the rectifier take down the tach signal if it is bad? I do get an a/c signal from the yellow wire when cranking so it would seem the stator is OK. Any help is greatly appreciated!
