Tach problem 2006 75 hp
bassinmike
I have a 2006 Merc four stroke Model: 75ELPT 4S, Serial # 18271556.* The tach is not working, I have a service manual in which the first step is to remove the "green" wire I have no such color of wire.
* This is a Lowe Stinger boat. The Tach is Veethree electronics 780049PMNB & it is a plug in style (original & when I took it out it was set @ 6P
I have the following wires & did get info from Veethree: Blue (power to light), Blk (ground), Purple (ignition), Gray (sender)
* With key turned on (boat NOT running)* I have Blue 12volts, Purple 12volts, Gray 1.7volts & ground must be o.k. as I used it for these test's.
* I have worked on 2 cycle's before & everytime the tach was not working the charging also did not work, replaced voltage reg & all good. However in this case charging is working 14.5 - 15volts. By service manual there is only a ground & red power wire comming from the regulator / rectifier. Also the service manual is very unclear as to where the gray wire goes on engine.
** ? - Where does this model of 4 stroke get its tach signal. Yes I realize a 4 stroke needs a certain type of tach (I believe as with the original any thing with a 6P setting. Can I use my voltmeter & with boat running back probe the gray wire, will this give me some kind of reading.
* Out of curiousity I tried a shop test of tach, used a battery & put black to ground, purple to positive & then used another positive lead to tickel the sender & this did make the tach to read a little.
Re: Tach problem
The signal does come from the regulator / rectifier. On a 6P setting. Any boat tach will work. Either green or green white. That might turn into a gray wire.
The tach cricuit test in the O.E. manual says to check between the 2 green/white leads of the regulator for 0 ohms. No mention of any volts test, but i would think that you would see ~14 volts AC with the motor running.
Re: Tach problem
Local Merc dealer says the same thing, tach signal comes from Volt reg/rec. I have the Merc manual for this model year & it shows ONLY a RED wire from reg/rec to main wiring harness, manual says a green sending wire which somewhere in boat changes to a gray wire. I followed through the wiring diagram & appeard to me the "green" sending wire came from the computer, As said local Merc dealer says reg/rec, so I went to an OMC dealer & master mechanic, he was very willing to help me out & took the time to look through Merc manual & confirmed that tach signal comes from computer.
Shame a person needs to go to OMC for Merc problem.
