Tach for 60 Hp Johnson
M
Mike A
Guest
How do I hook up a Tach for m
How do I hook up a Tach for my motor. Is it simply wired in or is it more complex? When I lift the cowling off and look where the battery and starter wires go in I have noticed a couple of capped wires sitting there. What do these wires do. Also does anyone know where to find 60's style gauges?
" Mike.... You need a tachomet
" Mike.... You need a tachometer that operates off the charging system. The tach must be capable of being set to operate off a six (6) pulse charging system (OMC's setup).
OMC's tachs will have a dial on the back, set it to six (6). The tach usually has four wires.
RED = To light switch.
Black = To ground.
Purple = To 12v supply but only when key is ON.
Gray = To Yellow/Gray rectifier wire. This wire is usually all GRAY at the instrument wiring harness.
Joe (30+ Years With OMC) "
