Will any of these Unisyn gauges fit over the opening of a Solex PAI 44 downdraft carb? The ones I have seen online seem to be only 3" across, which I believe to be too small.
EDIT: Sorry, I was thinking of how big the flame arrestors are...never mind, I am pretty sure the carb opening is 3" or smaller.
There's this picture in the Solec manual of a coffee tin over the PAI 44 for the Unisyn guage - I have one but haven't used it yet. The old timer who tunes my AQ 151 engine put his hand over the twin carbs to feel for airflow and just twiddled both the screws (air/fuel and idle) on each carby whilst listening to the engine. Engine runs OK and who am I to reason why but I am sure I can smarten things up a bit down the track.
Before adjusting the carbs be sure and adjust the points with a dwell meter at 62 de (grees +/- 3 degrees and confirm base timing at 6 DBTDC. If your still running points the dwell angle makes all the difference in the world especially at idle speeds. Allways adjust the timing after you set the point gap with a dwell meter.
Start your own thread it is not polite to hyjack someone elses.All good info: to know and hopefully remember Kim.
Have a question about the spark gap - my "old timer" made the gap significantly wider (can't remember the reading offhand) with a comment that my Petronix distributor allowed for this and this also made for easier starting. Any hints as to what the gap should be on my Bosch pugs on my AQ 151 with elect ignition?
