Eric.C
***EDIT: Ooops... there is an electrical forum. Should I delete this and repost there?
I recently installed a new Faria Synch Gauge. If I am idling, it is nearly impossible to keep the gauge showing synched, but it seems to work properly. If port is at 800 and starboard at 1000, it points toward port; and vise-versa. Seems to swing appropriately and work fine at lower RPMs.
As soon as we throttle up, however, it starts to lean to the left (port supposedly slow) and basically stick there. I can run port up well beyond starboard (3k/2k), and the gauge still says port is slow. I can keep port at 3000 and pull starboard completely offline and the gauge still does not move; but as soon as I pull both of the engines down below ~2k, the gauge seems to "unstick" and float freely, and accordingly with the engines.
Any thoughts? Seen this? The tachs move, but the synch freezes... ?? Bad synch gauge? I don't want to return it and have the replacement do the same thing, you know?
Already looked at Faria's FAQ and such. Verified the selector position on the back of the gauge, etc..
I have read others on here mentioning ignition coils should be on relays. Ours are not. They are powered directly off the igntion switch. Could it be a current draw issue? Too much power being sucked through a 30-foot 10ga wire?
Any ideas are appreciated. Thanks in advance!
