I have 2007 8.1L Crusaders with Sync-N-Cruise and a Murphy display panel. My problem is the slave engine lags about 100 RPM lower than the master. I first noticed the drone/beat frequency noise then check RPM. Tried it under load up to 3400 RPM and in neutral at the dock. Same result in both cases.
Engines running smooth. Changed fuel filter. Spark plugs have about 15 hrs on them. Checked for loose plug wires. I did not run un-sync'd at full RPM under load. Should try that.
The slave has an extra accessory that is belt driven and provides more load on that engine. It is a hydraulic pump. When I took the belt off the pump then the Sync-N-Cruise worked properly. RPMs were matched. So it looks like the extra load slows the slave down. I don't recall this much mismatch in RPM ever before. Seems nothing has changed.
Does the Sync-N-Cruise look at only throttle position or does it see real RPM?
Are there any sensors involved that could affect this?
Any parameters to look at on the Murphy?
Thanks for your help.
