R
Reginald Quinn
Guest
"I have a 1998 Baja 192 mercru
"I have a 1998 Baja 192 mercruiser 5.0L 220 hp 2 barrel carb. I posted about how it would surge between 2000 - 3200 rpm and make the boat porpus at WOT. But run prefect at idle and started great. I changed fuel water seperator, tried spray in carb cleaner as well as STP fuel add carb cleaner and no change. I ran the boat for a couple hours putting around the lake at idle only. Tonight I took the boat and no surge and ran great and WOT. After running it hard and backing off the gas the boat would begin to fight to stall and if you put it in neutral it would stall. It starts right up and run fine after the stall. Dirty carb and the stuff is just moving around? Electric fuel pump?"
