Sx drive vibration and knocking in turns (completely stumped)
Monster1
Hey guys, first post here. It's my understanding that there are some real smart people here that might be able to help me out with my problem. Here it goes. I have a 04 2101 striper with 4.3gxi engine and sx drive. I have a ss ballistic 14 x 17 pitch prop. No damage. When running the boat in even slight turns, I get your standard vibration/groan and sometimes knock which suggests the gimbal bearing and/or u joints. The drive has been serviced numerous times since I've been aware of this issue. The gimbal bearing and driveshaft are new. It has not helped the problem. EVERYTHING looks new. The shop I take it to is a professional shop with Volvo trained techs although they are not a Volvo dealer. They have checked alignment (not with a tool but they say it the driveshaft won't go back into place of engine is misaligned), checked all mounts, new driveshaft, new gimbal, etc. Everything is nice and clean, no rust, no metal shavings, shiny wear areas, no nothing. They are stumped what is causing this issue. They even contacted a Volvo rep who was reluctant to help because this drive isn't under warranty and they aren't a dealer. Tgey basically told them it's just the way it is. I find this unacceptable as it's not like the problem us from locking out the steering wheel at turns doing 40mlh across the water. The problem is occurring with the drive swinging as little as 15 degrees either way or even just trimming the engine enough for optimum cruising. If I swing more such as coming back around to pick up a skier in the water, the vibration/groaning turns into knocking. For a lack of better description, the knocking is like when you vibrate your tongue against the roof if your mouth. If that makes sense. I've even contacted another volvo shop and their star tech told me that if there aren't any broken parts or shavings, shiny wear areas, etc just run it. On some days I'm inclined to just follow their advise but in other days I'm just thinking this is unacceptable. If I take the boat out again, I'm just going to have to take a video of the noise problem and show just how little I turn the drive because it starts vibrating and groaning. Please help guys. I'm at my wits end.
Thank you,
Monty
