pietropesci
"Hi there, please help me to u
"Hi there, please help me to understand if I did a mess! I was in need of repowering a boat of mine, and purchased from a sale two 318 counter-rotating engines, with their two transmissions(velvet 1017-004)coming out of a twin engine boat, after having tested them still in the boat. As only the left engine and the right transmission were working good, I thought to put them together and install everything in the boat, but, as I experimented today, the engine works good, but not the transmission, whatever I do, whenever I push the lever, it goes on slightly turn counterclock, while the engine is a right rotation, and I'm able to stop rotation just gripping the axle with my hand, also when I throttle up the engine: does the transmission oil pump only works with the right side engine rotation? This is the only cause I can figure out. Please help me if you can!!!! Pietro"
