Bluecollerboater
I have a 1994 Volvo penta Gipmda. I had the long block replaced and was having all kind of problems with the fuel injection so I had the ignition system changed and put a carb on it.it was a thunderbolt 4 ignition and 750 cfm carb off a mercruiser 454 it runs great now but my mechanic says it will only get to 4200 rpm with no fuel or water or family junk on board. the gimda spec is 4600-4800. now it Is a carbed 350. so I am assuming it is a 260 horsepower motor not unlike a AQ 260A. what rpm should I get?
Mechanic says I should switch from the B-5 that is on there now to a B-4. It is a DP-C 1.95.
I am not sure what rpm I should get at WOT. And which prop, B-4 or B-3 to achieve it.
Thanks in advance for any help.
