Switch OMC drive for a Mercruiser
herve88
I have a 1969 Slickcraft with
I have a 1969 Slickcraft with a GM 307 engine with a Johnson/OMC outdrive. Is there a way to mount a Mercruiser on to that engine?
"You would have to remove ever
"You would have to remove everything and then install a complete Merc transom assembly inner and outer, and the Merc drive.
You would also have to change the engine bellhousing over to a Merc.
Best bet would be to find a wrecked boat with a serviceable engine & drive.
I beleive the older OMC drives used a much larger transom hole than the Mercs. so you might also need to do some kind of transom filler/rework first. Maybe someone else here knows if this is possible??
Rod"
"A bigger problem is that the
"A bigger problem is that the OMC stringer drives coupled thrust to the hull by being bolted to the boat's stringers. The transom is often built just like the sides of the boat, as it doesn't bear any thrust or weight load.
A Mercruiser transfers the propeller thrust and engine weight through the transom plate. This means that a reinforced transom is a requirement. It can be a lot of work to beef up the transom. In any event, the transom opening for the OMC is much larger than you need. This would need to be reinforced and glassed up strong enough to take the load that would be placed upon it.
As for the 307....I don't know. I suspect your best bet would be to find a complete engine/drive assembly from a junk boat and install it.
If the OMC drive is working properly, you are further ahead to run it. Most parts that require routine service are still available. Some components are getting pretty rare though. Thankfully, these parts don't break much, otherwise someone would be making a buck by selling them."
"[b]"Is there a way to mou
""Is there a way to mount a Mercruiser on to that engine?"
Ayuh,....
The short answer to that question is,....
No way in 'ell can it be done....."
