97 Force 40hp #oe228953. The switch box wire to coil reads 13.5 volts when unplugged from coil but reads 4 volts when plugged to coil harness. This is with ignition switch off,kill wire unplugged and stator unplugged. I have a 10 amp draw on battery because of this. Doesn't matter which coil is plugged in I get the same reading. My question #1 is the tan switch box wire supposed to be hot with ignition off? The engine runs smooth but will not turn over 2000 rpms also the stator ohms at 685 which seems to be in spec. Is my switch box bad?
