the_last_hour
"If I'm swapping my holley
"If I'm swapping my holley carbs on my 5.7's, is it necessary to replace gasgets ( they are 1 year old), Is there anything special I need to know about removing the metal fuel line to the carb? (special tool,sealant?) The reason for the swap, is one engine burns 15-20% more fuel according to floscans, it is evident at all rpm ranges, including idle. I want to see if the efficiency problem follows the carb. The carbs only have two mixture screws to adjust, one left and one right. How should they be set? The carb that is not efficient does not react much when the right mixture screw is all the way in, but needs some idle screw adjustment to get up to 750. The efficient carb is very sensitive to the right mixture screw and the only way for me to get it below 750 rpms is to close it a little. The timing is the same on both engines."
