bought this 290 single prop out drive that was off a 171c 4 cyl petrol motor that I want to fit onto my AD41B 6 cyl. I've also got a lower duo prop leg that I want to replace the single prop leg, what I want to know is would this be fine to do.
The lower leg was off a diesel 6 cyl so this should be fine just the upper gear box I'm not sure on if it will run the duo prop leg
The only numbers I can see on the housing is PZN 029010664B
If you can help me out that would be fantastic
