"Help. I just acquired a 1972
"Help. I just acquired a 1972 luhrs with a 318 motor. The boat was actually free from my neighbor. While working on it , I found out the motor was hydro locked, probably from the salt water cooling system rotting out the heads. I lucked out and got another 318, from a 1973 luhrs with twin 318's complete with the trans and vee drive all in one unit. The motor runs great. I bench ran it and it hums real nice, and it is the correct rotation. My problem is I cant disconnect the mounting bolts from the coupling where it meets the shaft of the old vee drive in the boat. The bolts are rotted, and they get rounded when I tried to loosen them. I also can't turn the shaft to reach all of the bolts. I also noticed the coupling on the 73 trans looks different than the one in the boat. Maybe its me, or I just cant see too well under there. My questions are. Is there any way of getting those bolts off the coupling? Also will the 1973 motor and trans bolt up to the shaft in the 1972 luhrs? and finally if I cant get the coupling bolts out, would I be able to leave the existing trans in and just use the 1973 motor, The trans and vee drive in there are sound. I really dont know marine engines, I know about cars.Any help would be really appreaciated. Oh, P.S the new motor is fresh water cooled, but I dont think it would be a problem hooking the cooling hoses from the new motor to the old trans. Thanks"
