Swap 302 ford merc cruiser
tdancz
"i need to swap my 302 ford me
"i need to swap my 302 ford merc cruiser for another one, i need some advise, i have a 1972 24` sea ray, with a merc cruiser outdrive, do i need to remove the outdrive,& if so should i remove it in 2 parts, any info or tips or tricks on this would be great thanks, terry"
"HY STAT after the outdrive is
"HY STAT after the outdrive is out looks like the motor should just come forward then up, is that correct? also any other info on this would be great, like any info on putting it back in, thanks again"
"to remove motor you pull the
"to remove motor you pull the 2 long bolts out of the rear gimbal housing mounts (1/2 NC bolts - 3/4 socket), then remove the front mounts. You have to lift up before you come forward. Removing the exhaust manifolds first makes it easier to work around the motor.
Guy, you mean a 351? He has a ford.
Terry- free merc manuals for download:
http://www.marineengine.com/discus/messages/12486/172197.shtml"
"HyStat:
Your right, 351.
"HyStat:
Your right, 351. My neighbor has a 1988 351 w/4BBL carb center hull mounted engine skiboat that will haul 6 skiers. He said it's easy on gas w/2 skiers."
