Suzuki wiring guru's help identify?
catfishin_welder
2008 DF 50 at remote box end:
Single white wire w male bullet connector...ecm fuse wire?
Black wire and yellow wire on small plug?
White wire green tracer, red, yellow w green tracer,blue on small plug?
White wire yellow tracer, thicker gauge red, black, black w white tracer, red w female bullet connectors...gauges?
Any info helpful. I've got the 2 main plugs attached at remote and engine cranks and t/t operates as it should. Im assuming others are gauges etc.?
From a 2009 DF90A, not your engine but might be close enough to give you an idea.
