Suzuki locks up
P
Paul Ponzetti
Guest
"The engine runs good when run
"The engine runs good when running. & when shut off, it shuts off normally, not like a sudden stoppage engine. However, the next time trying to start it a week later, the engine is locked up. Starter is O.K. It was taken off and checked out. The starter won't turn the fly wheel. After squirting oil in cylinder thru spark plug holes and waiting a few days, the engine starts. Had both heads off and there was no scoring in cylinders. The fly wheel was loosened with a long handled wrench on a time or two, then it would start. Any suggestions on this problem?"
Have you checked the lower uni
Have you checked the lower unit gear oil.Water in the oil? Freezing climate????
