New in this forum, from Norway so there will be some typing errors!
I have a 1996 Suzuki DT90.
It starts fine, idles good. But after 15 seconds it stops. It will start instantly after shutdown.
The alarm sounds every 5 second, and sounds for just about a second.
The TPS is new, ignition timing resistor is new, carbs rebuilt, fuelpump rebuilt,
water pump impeller is new. good compression.
If i disconnect the TPS it will run for hours, but as soon I connect the TPS it stops. Thats why I bought a new. But that didnt change anything.
When it runs with TPS disconnected the alarm still sounds as mentioned.
Do anyone have an idea? Is there anything I should check?
