"I need some help with power t
"I need some help with power tilt problem. I recently got this motor (1985 I think) with a spare trim motor as the old one did not work.
I switched it around, reconnected wires to motor, refilled fluid by raising the motor manually, adding fluid, let it it lower by itself and did it over till I think I got most of air out.
When I switch it up or down, I hear the motor spinning, but it does not do anything else. I don't have a manual, so not sure if it's something to do with the valve on bottom of pump.
Right now, it is tightened all the way.
Can someone please help me out?
Thanks!!!"
Thanks!!!"
