Suzuki DT40 Wont crank
ridgy
"There is power, trim works. t
"There is power, trim works. though when key turned nothin happens. assuming it may be starter motor..starter does not engange.. although could be ess?? any thoughts. cheers"
Does anything power up when yo
Does anything power up when you turn the ingnition on? If no than I would check for a fuse on the ignition side.
turns out i think it may be th
turns out i think it may be the starter solenoid.. would that be expensive to replace?
"well next is to c if u have 1
"well next is to c if u have 12v to starter relay/solenoid
if so then turn the key and see if the meter gets 12V, this means the key switch is working"
