Suzuki DT40 Outboard
meverett
"I have the above 1987 outboar
"I have the above 1987 outboard engine and it runs pefectly out of the water and connected to flush muffs and a hose.
My problem is that when it is in the water it will not give me full power, it seems like it is being choked and only give me less than half power.
Could it be that the mixture is not set correctly for the exhaust being in water and is being restricted by the water?
I have noticed that it sits quite low in the water and the higher exhaust outlet is also in the water. Could it be that I need to raise it on the transom?
Any advice would be greatly appreciated."
The prop had damage to one bla
The prop had damage to one blade but I have now repaired. Could the above problem be due to an out of balance prop?
Any help would be greatly appreciated.
"Never heard of a prop shop re
"Never heard of a prop shop repairing a prop to have a blade off balance, however try a spare prop to ease your mind."
Maybe the prop is not the prob
Maybe the prop is not the problem.
Any ideas why the engine would rev properly out of the water and connected to flush muffs but not when it is in the water?
Please any ideas would be appreciated.
I have got 110psi on both cyli
I have got 110psi on both cylinders but looks like no spark on one plug. Plug is OK as used the same one for both checks. The coils are a sealed unit in with the CDI. Any ideas how to test this?
Many thanks to all.
Martin. (UK)
