bigbass14.3
I have '89 Suzuki DT150 super six that I am having problems with I can put it in the lake it will start and idle great even rev up fine, when i put it in gear and idle out to no wake buoy and give it throttle to come up on plane it doesn't even try to go any faster stays same rpm as slow idle speed. I have rebuilt carbs, new fuel pumps, hoses from tank to motor, replaced voltage regulator new plugs and compression check was good, I am at a total loss only thing I can come up with is maybe a throttle position sensor but I hate to keep throwing parts at it. can anyone help me with this? ( back story motor ran great had clutch dog break in lower unit and replaced when I got it back the fuel line blew off the bottom carb. after replacing fuel lines with new ones this problem started.)
thank you
Jason
thank you
Jason
