portatejas
I have a 2015 DF175 The oil light is " Staying lit" its solid light NOT blinking
This happened after a recent oil change. I reset the " blinking " oil reminder, then a couple days later the oil light cam on and will not go out
The motor is running fine, it will run up to whatever speed I want as well as RPM ...my understanding is that if it was a true " oil pressure " issue the motor would go I to a limp mode...this does not happen...I'm assuming it's the oil pressure switch or the tach? .....Any ideas???
