Hello, I’ve had this outboard for almost 5 years since I purchased new in October of 2020. It’s been kept up to service yearly and flushed extremely well after every use with only 116 hours . Ever since about a month ago it’s been throwing the red light and goes into limp home mode . I’ve read lots of threads of it being the water jackets clogged and mechanic told me it needs to be descaled . First I replaced the whole water pump system new , replaced the thermostat, anodes , oil filter , engine oil (full 100hr service) I checked the temp sensor as well . Water is circulating well through the water pump as the tale telI is strong . I purchased rydlyme and hooked up a submersible pump with the lower unit removed through the water pick up under 5 gallon bucket and let it recirculate for hours as it cleaned a lot of stuff from the inside thinking my problem would be solved (I removed thermostat during the descale), I purchased SDS cable and the engine isn’t showing any failure codes . Engine is still going into limp after all this and showing as an over heat gradient on the computer . Anyone ever come across this issue or are these engines just junk ? I’ve tried just about everything I can before taking it back to mechanic or having to disassemble the block / power head . Anything helps at this point I’m stumped . Thanks !
