Both of my 2006 DF115's will beep and blink check engine lights after about an hour on the water. No change in performance, temp etc. engines run perfect. Code seemed to be 2-2 but that would be air intake and would go into safe mode which is not happening. Mechanic says computer is not reading any check engine codes in over 250 hrs and can't find problem. Has anyone had a wiring issue or otherwise that has caused faulty codes? If so how did you fix issue? Thanks for any input!
