Suzuki DF 140
tugela
G-Day
Motor stalled, alarm Map sensor 2 fault. Re start with idle speed increased, engine restarted but cutting out, mechanic cleared blockage cmp sensor. Have noticed after last service light oil or fuel surface slick originating from prop when motor running. The leak is now more noticeable after motor back up and running. Any suggestions on possible cause of discharge?
Cheers
Looking at your problems and hopefully you may have it sorted by now. I am looking to purchase new DF 175 and very interested in your issues. If its still under warranty should be a dealership fix but I am concerned on the confidence level if relative new.
Regards
strategy
Hi
Motor is 4 years old with 250hrs problem was more lack of use, after cleaning AIC valve ran motor no problems at 5500rpm.Only concern is light slick originating from prop.
Tugela
