Hi, I recently took my 2018 Suzuki 115 out and it wasn’t peeing when it had been previously. I was able to idle back to the dock which was about a 30 minute trip and it never overheated. I took it home and put a new impeller kit with gaskets, etc… in it. I put it on the ear muffs and she wasn’t peeing so I went through and blew out each of the water lines around the motor and it doesn’t appear that anything is clogged. I was able to attach a hose to the flush port and water comes out the intake at the bottom and through the prop as well as it pees perfectly like that. Would I be able to rule out a clogged line if that was possible and what else might be causing her not to pee all of a sudden? We did the impeller replacement step by step alongside a video and believe we couldn’t have messed up anything there. Any ideas on what to try next? Again, I can start it and run it and it doesn’t appear to be overheating. I’m even put it in a Tupperware container so that the intakes were covered up by a couple of inches. She’s peed on just the ear muffs before as well.
