Suziki 5hp artic 2stroke
bayoudon
"i have water in my gear oil,i
"i have water in my gear oil,i ckecked the seals on the two screws,they are ok do i have a seal leaking around the prop? thanks bayoudon"
well if it leaks oil on the fl
well if it leaks oil on the floor its certainly a prop shaft seal if it was mine and you want to do it right change all the seals the prop shaft and drive shaft seal but if you just want to keep it moving take the gearcase off drain the oil and pressure test see witch one is leaking
thanks for the help! it does n
thanks for the help! it does not leak oil on the floor it has a milky color in the lower gear box gear oil after its been run in water. bayoudon
well its not geting much water
well its not geting much water init then if you run it once a month or so just change after every use but if its a daily or weekly runner fix it
