Stupid 1985 85 hp question
norm_trenaman
Installed my new stator on my
Installed my new stator on my 1985 85 hp and get good spark - so I get the earmuffs out to see if it will start. But where are the water intakes? I see two rectangular holes about 2 inches in front of the prop? Are these the water intakes?
My earmuffs will not go wide enough to fit over the prop housing - are there earmuffs specific to Force engines? I suppose I could use a garbage can but the bottom ends looks pretty big for any garbage can I have ever seen.
BTW - thanks to Graham Lamb for his stator advice. I used an 1988 stator as a replacement for my 1985 - was a perfect fit - just had to crimp the 1985 2 pin connectors to the proper wires on the 1988 stator.
"-My earmuffs will not go wide
"-My earmuffs will not go wide enough to fit over the prop housing
Same on my 90Hp Chrysler
-Are these the water intakes?
Yes
-are there earmuffs specific to Force engines
Should be, I have not found them. <"
"Flushing device for Force mot
"Flushing device for Force motors is Merc part number 820634 - available from any Merc dealer for 16 bucks and change.
