stumpted
Wayne Mckenney
on my 1983 70h.p.evinrude when i adjust my timing to tdc for pickup timing the motor revs to 4000 rpm with noway to idle it down. the carb. plates are closed.
Timing on outboards does not normally require adjusting !-------So set the timing at full throttle only and it will be correct at idle.-----------You must follow instructions in your manual.
As racerone stated there is no reason to adjust timing unless something was replaced or the adjustment was moved. Advancing the timing on this engine will increase the rpms with out the throttle being opened.
If you have a service manual, you're misreading it. There is no method for setting the timing at TDC... the only reason for finding top dead center is to adjust the timing pointer, to make sure it is accurately situated, and that is done by using a special tool as per your manual.
Hopefully you did not change the measurement on the cam rod (rod between the vertical throttle arm and the metal cam that slides against the throttle cam roller) by screwing the nylon clevis in or out. If you did, you'll need to set the idle timing pickup setting as per your manual.
If you didn't change the idle pickup setting, you should be okay and you can check the full spark advance setting without the engine running as follows.
(Timing At Cranking Speed 4°)
(J. Reeves)
NOTE: If your engine has the "Fast Start" feature", you must disconnect/eliminate that feature in order to use the following method. The "Fast Start" automatically advances the spark electronically when the engine first starts, dropping it to normal when the engine reaches a certain temperture.
The full spark advance can be adjusted at cranking speed,"without" have the engine running as follows.
To set the timing on that engine, have the s/plugs out, and have the throttle at full, set that timer base under the flywheel tight against the rubber stop on the end of the full spark timer advance stop screw (wire it against that stop if necessary).
Rig up a spark tester on the #1 cylinder plug wire. Hook up the timing light to the #1 plug wire. Crank the engine over and set the spark advance to 4° less than what the engine calls for.
It's a good idea to ground the other plug wires to avoid sparks that could ignite fuel that may shoot out of the plug holes. I've personally never grounded them out and have never encountered a problem (fire) but it could happen.
I don't know the full spark advance setting your engine calls for, but to pick a figure, say your engine calls for 28°, set the timing at 24°. The reasoning for the 4° difference is that when the engine is actually running, due to the nature of the solid state ignition componets, the engine gains the extra 4°.
If you set the engine to its true setting at cranking speed, when running it will advance beyond its limit by 4° which will set up pre-ignition causing guaranteed piston damage! You don't want that to take place.
No need to be concerned about the idle timing as that will take care of itself. The main concern is the full advance setting.
Be sure to use your own engines spark advance settings, not the one I picked out of the air here in my notes.
Idle pick-up timing is often mis-understood.-------------Good that you got everything back to where it should be.--------Were there any issues with the running of the motor that led you to adjusting the timing ??
yes, the issue was the engine would idle and run wot fine but to go from idle to plane you had to ram the throttle wo. slowly advancing the throttle would bog and stall the mtr. i had cleaned and soaked the carbs more times than i can recall so i was trying to see if the timing was an issue
