markkingscraft
"Last year I installed two reb
"Last year I installed two rebuilt 318s.
They had been rebuilt about 10 years ago and although the cylinders etc were clean - no rust - had been oiled and turned regularly - the rings appeared stuck to the pistons.
Compression test on all cylinders in both engines was between 95 and 115.
After about 10 hours of running, the starboard engine is improving. I have 155 in one cylinder and 115 to 125 in the rest.
When I do a wet test I get 150 to 155.
This engine has a water pump problem and has been running fairly warm. The side where the one cylinder has come back was steaming hot on a few runs.
Port engine is another story. It barely comes up to temp ( I run in the St. Lawrence River where the water temp is chilly all the time) and compression is still 95 to 100 in all cyclinders.
I have dropped some MMO in the cylinders for a few days, added some to the oil as well and am now using it in the fuel.
I am going to run this engine without the water pump to heat it up to try and heat / cool the rings free.
With no water in the engine how will I know when it is getting too hot? Can I use a spray bottle and squirt water anywhere for an indication?
Anyone have any ideas?
Mark"
Mark"
