Stripped out spark plug holes
mrfox143
I have an Evinrude 1961 5.5 hp
I have an Evinrude 1961 5.5 hp. One of the plug holes is stripped any idea what size helicoil I need? Alos have a 40 hp Johnson 1967 with the same problem.
Would appreciate any help you can give.
John
Heli-coil makes a kit just for
Heli-coil makes a kit just for plug holes Just tell them the plug size..an easy job...! Tom
"John, The J4C plug used in y
"John, The J4C plug used in your 40HP is a 14 MM.
There is also a solid insert which you can use instead of the helicoil. I like the solid ones better. Epoxy them into the head."
